The python crazyradio lib can be found in the Crazyradio git repos https://github.com/bitcraze/crazyradio-firmware/blob/master/lib/crazyradio.py. It is a single file that implements the low level Crazyradio dongle functionalities.
The Crazyradio is configured in PTX mode which means that it will start all comunication. If a device in PRX mode is on the same address, channel and datarate, the device will send back an ack packet that may contains data.
Crazyradio Device
_ _
| Packet |
| Ack |
Ths is an example on how to use the lib:
import crazyradio cr = crazyradio.Crazyradio() cr.set_channel(90) cr.set_data_rate(cr.DR_2MPS) res = cr.send_packet([0xff, ]) print res.ack # At true if an ack has been received print res.data # The ack payload data
None
| Name | _ _init_ _ (Constructor) |
| Parameters | (USBDevice) device, (int) devid |
| Returns | None |
| Description | Initialize the Crazyradio object. If device is not specified, a list of available Crazyradio is made and devId selects the Crazyradio used (by default the first one) |
| Name | close |
| Parameters | None |
| Returns | None |
| Description | Close the USB device. Should be called before closing the program. |
| Name | set_channel |
| Parameters | (int) channel |
| Returns | None |
| Description | Set the Crazyradio channel. Channel must be between 0 and 125. Channels are spaced by 1MHz starting at 2400MHz and ending at 2525MHz. |
| Returns | None |
| Name | set_address |
| Parameters | (list of int) address |
| Returns | None |
| Description | Set the Crazyradio address. The address is 5 bytes long. It should be a list of 5 bytes values. |
| Name | set_datarate |
| Parameters | (int) datarate |
| Returns | None |
| Description | Set the Crazyradio datarate. Datarate is one of DR_250KPS, DR_1MPS or DR_2MPS |
| Name | set_power |
| Parameters | (int) power |
| Returns | None |
| Description | Set the Crazyradio transmit power. Power is one of P_M18DBM, P_M12DBM, P_M6DBM or P_0DBM respectively for -18dBm, -12dBm, -6dBm and 0dBm. |
| Name | set_arc |
| Parameters | (int) arc |
| Returns | None |
| Description | Set the number of retry. 0<arc<15. See nRF24L01 documentation for more info. |
| Name | set_ard_time |
| Parameters | (int) us |
| Returns | None |
| Description | Set the time to wait for an Ack in micro seconds. 250<us<4000. The wait time for an Ack packet corresponds to the time to receive the biggest expected Ack. See nRF24L01 documentation for more info. |
| Name | set_ard_bytes |
| Parameters | (int) nbytes |
| Returns | None |
| Description | Set the time to wait for an Ack in number of ack payload bytes. The Crazyradio will calculate the correct time with the currently selected datarate. |
| Name | set_cont_carrier |
| Parameters | (bool) active |
| Returns | None |
| Description | Enable or disable the continious carrier mode. In continious carrier the Crazyradio transmit a constant sinus at the currently set frequency (channel) and power. This is a test mode that can affect other 2.4GHz devices (ex. wifi) it should only be used in a lab for test purposes. |
| Name | scan_channels |
| Parameters | (int) start, (int) stop, (int) packet |
| Returns | (list) List of channels that Acked the packet |
| Description | Sends \packet\ to all channels from start to stop. Returns a list of the channels for which an ACK was received. |
| Name | send_packet |
| Parameters | (list or tuple) dataOut |
| Returns | (_radio_ack) Ack status |
| Description | Sends the packet dataOut on the configured channel and datarate. Waits for an ack and returns a _radio_ack object that contains the ack status and optional ack payload data. |
| (bool) ack | At True if an Ack packet has been receive (ie. if the packet was received by the device) |
| (bool) powerDet | Indicate the nRF24LU1 power detector status. See nRF24LU1 documentation for more information. |
| (int) retry | Number of retry before an ack was received |
| (tuple) data | Data payload received in the Ack packet |
None
