projects:dockerbuilderimage:index [2015-12-28 16:31] kristoffer created |
projects:dockerbuilderimage:index [2021-06-24 16:16] (current) kimberly |
| - | ====== | + | <WRAP center round important 60%> |
| + | This page has deprecated and moved to the new documentation framework of the main Bitcraze | ||
| - | We have created a Docker image with all the tools needed to build the Bitcraze projects, In the image, we have installed compilers for the processors that are used in our hardware as well as python for the python client. | + | ====== |
| - | The builder image is used when building the project | + | The toolbelt |
| - | The image is available at [[https:// | + | The docker |
| - | Documentation | + | The builder images are also used when building the project |
| + | The source code can be found on [[https:// | ||
| + | ===== Installation | ||
| + | Instructions | ||
