We have created a Docker image with all the tools needed to build the Bitcraze projects, In the image, we have installed compilers for the processors that are used in our hardware as well as python for the python client. The goal is to make it easy to build Bitcraze code without having to install various tools with the complexity of supporting multiple operating systems.
The builder image is used when building the project on our CI server at travis, why it can be considered the official build environment.
The image is available at Docker Hub and the source code can be found on github.
Documentation on how to use the image is available in the source code and on Docker Hub.
