Next revision | Previous revision Last revision Both sides next revision | ||
projects:lps:deck [2016-05-24 14:21] arnaud created |
projects:lps:deck [2016-05-26 16:09] arnaud |
- | ===== Loco Positioning deck ===== | + | ====== Loco Positioning deck ====== |
The Loco Positioning deck is designed to be installed on the Crazyflie 2.0 deck port. The orientation is indicated using the standard deck orientation [[projects: | The Loco Positioning deck is designed to be installed on the Crazyflie 2.0 deck port. The orientation is indicated using the standard deck orientation [[projects: | ||
Line 8: | Line 8: | ||
* **SFD**: Received packet timestamp | * **SFD**: Received packet timestamp | ||
* **RXOK**: Packet received without error | * **RXOK**: Packet received without error | ||
+ | ===== Firmware ===== | ||
+ | The firmware for the DWM deck is included in the Crazyflie 2.0 firmware build (recent) and activated when the deck is attached. The deck contains a small memory that holds the address of the board as well as the addresses of the anchors it will use for ranging. | ||
+ | More information on building the firmware and the firmware itself can be found [[https:// | ||
+ | ===== Schematic ===== | ||
+ | Loco positioning deck schematic: {{: | ||
