projects:lps:node [2016-05-26 16:38] arnaud [Building and flashing] |
projects:lps:node [2021-06-24 16:15] (current) kimberly |
====== LPS Node ====== | ====== LPS Node ====== | ||
Line 9: | Line 14: | ||
- **Terminal**: | - **Terminal**: | ||
- **Reset**: Reset the board | - **Reset**: Reset the board | ||
- | - **Exp connector**: | + | - **Exp connector**: |
- **USR & DFU**: If pressed and held during reset or power on this will put the board into DFU bootloader mode. When the system is up and running the button is unused, but could be used to trigger functionality in the firmware. | - **USR & DFU**: If pressed and held during reset or power on this will put the board into DFU bootloader mode. When the system is up and running the button is unused, but could be used to trigger functionality in the firmware. | ||
- **SWD**: Connector for programming and debugging MCU. Uses same pin-out as Crazyflie 2.0 and [[http:// | - **SWD**: Connector for programming and debugging MCU. Uses same pin-out as Crazyflie 2.0 and [[http:// | ||
Line 30: | Line 35: | ||
+ | [[doc: | ||
==== Building and flashing ==== | ==== Building and flashing ==== | ||
Building and flashing is described in the [[https:// | Building and flashing is described in the [[https:// | ||
Line 41: | Line 49: | ||
===== Schematic ===== | ===== Schematic ===== | ||
- | Schematic of the Loco Positioning Node: {{: | + | Schematic of the Loco Positioning Node: |
