projects:lps:node [2016-05-24 14:17] arnaud created |
projects:lps:node [2016-05-26 16:50] arnaud |
Line 5: | Line 5: | ||
<WRAP half column> | <WRAP half column> | ||
Connects and buttons: | Connects and buttons: | ||
- | - **uUSB**: Used to power board (and will have command-line interface) | + | - **uUSB**: Used to power board (and have command-line interface) |
- **DC-jack**: | - **DC-jack**: | ||
- **Terminal**: | - **Terminal**: | ||
- **Reset**: Reset the board | - **Reset**: Reset the board | ||
- **Exp connector**: | - **Exp connector**: | ||
- | - **USR & DFU**: If pressed and held during reset or power on this will put the board into DFU bootloader mode. When the system is up and running the button is still unused, but could be used to trigger functionality in the firmware. | + | - **USR & DFU**: If pressed and held during reset or power on this will put the board into DFU bootloader mode. When the system is up and running the button is unused, but could be used to trigger functionality in the firmware. |
- **SWD**: Connector for programming and debugging MCU. Uses same pin-out as Crazyflie 2.0 and [[http:// | - **SWD**: Connector for programming and debugging MCU. Uses same pin-out as Crazyflie 2.0 and [[http:// | ||
- | - **FTDI**: Connector designed for the FTDI serial-to-USB cable (TTL-232R-3V3). | + | - **FTDI**: Connector designed for the FTDI serial-to-USB cable (TTL-232R-3V3). |
- **M3 mounting holes** | - **M3 mounting holes** | ||
Line 28: | Line 28: | ||
+ | ===== Firmware ===== | ||
+ | ==== Configuring the node ==== | ||
+ | The node can be used as: | ||
+ | * An anchor: receives and answer ranging requests | ||
+ | * A tag: Ranges with anchors and prints the distance | ||
+ | * An UWB sniffer: Prints all messages received from the radio | ||
+ | To configure the node connect it to a computer (I will assume a computer running linux but it should work on mac and windows as well). The node will be recognised as a serial port. The name of the serial port can be found with // | ||
+ | $ dmesg | ||
+ | [22942.980255] usb 3-2: new full-speed USB device number 13 using xhci_hcd | ||
+ | [22943.109845] usb 3-2: New USB device found, idVendor=0483, | ||
+ | [22943.109852] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 | ||
+ | [22943.109855] usb 3-2: Product: Loco Positioning Node | ||
+ | [22943.109858] usb 3-2: Manufacturer: | ||
+ | [22943.109861] usb 3-2: SerialNumber: | ||
+ | [22943.110697] cdc_acm 3-2:1.0: ttyACM3: USB ACM device | ||
+ | The serial port can be open with your favorite serial console, picocom: <code bash>$ picocom / | ||
+ | The node will print startup messages: | ||
+ | SYSTEM : CPU-ID: 1c0030000f51485336373420 | ||
+ | TEST : Initializing pressure sensor ... [OK] | ||
+ | TEST : Pressure sensor self-test ... [OK] | ||
+ | TEST : EEPROM self-test ... [OK] | ||
+ | TEST : Initialize DWM1000 ... [OK] | ||
+ | CONFIG : EEPROM configuration read and verified | ||
+ | CONFIG : Address is 0x1 | ||
+ | CONFIG : Mode is Anchor | ||
+ | CONFIG : Tag mode anchor list (6): 0x01 0x02 0x03 0x04 0x05 0x06 | ||
+ | SYSTEM : Node started ... | ||
+ | SYSTEM : Press ' | ||
+ | You can type h for help: | ||
+ | Help | ||
+ | 0-9 - set address | ||
+ | a - anchor mode | ||
+ | t - tag mode | ||
+ | s - sniffer mode | ||
+ | d - reset configuration | ||
+ | h - This help | ||
+ | All settings will take effect after reset. they are saved in an I2C EEPROM onboard. ' | ||
+ | ==== Building and flashing ==== | ||
+ | Building and flashing is described in the [[https:// | ||
+ | To make the project type: <code bash> | ||
+ | When developing on the node you will want to flash with an SWD debuger as it is faster and allow for debugging the code. The project is configured by default to use StLink-V2 but it can use any debugger compatible with OpenOCD. To flash with SWD type: <code bash> | ||
+ | For just flashing the latest version or for ocasional development flashing via DFU is good enough and does not required any additional hardware. Flashing via DFU requires [[http:// | ||
+ | ===== Schematic ===== | ||
+ | Schematic of the Loco Positioning Node: {{: | ||
