projects:lps:node [2016-05-26 12:54] kristoffer |
projects:lps:node [2021-06-24 16:15] (current) kimberly |
====== LPS Node ====== | ====== LPS Node ====== | ||
Line 9: | Line 14: | ||
- **Terminal**: | - **Terminal**: | ||
- **Reset**: Reset the board | - **Reset**: Reset the board | ||
- | - **Exp connector**: | + | - **Exp connector**: |
- **USR & DFU**: If pressed and held during reset or power on this will put the board into DFU bootloader mode. When the system is up and running the button is unused, but could be used to trigger functionality in the firmware. | - **USR & DFU**: If pressed and held during reset or power on this will put the board into DFU bootloader mode. When the system is up and running the button is unused, but could be used to trigger functionality in the firmware. | ||
- **SWD**: Connector for programming and debugging MCU. Uses same pin-out as Crazyflie 2.0 and [[http:// | - **SWD**: Connector for programming and debugging MCU. Uses same pin-out as Crazyflie 2.0 and [[http:// | ||
Line 30: | Line 35: | ||
+ | [[doc: | ||
==== Building and flashing ==== | ==== Building and flashing ==== | ||
- | Building and flashing is described in the [[https:// | + | Building and flashing is described in the [[https:// |
+ | To make the project type: <code bash> | ||
+ | When developing on the node you will want to flash with an SWD debuger as it is faster and allow for debugging the code. The project is configured by default to use StLink-V2 but it can use any debugger compatible with OpenOCD. To flash with SWD type: <code bash> | ||
- | Flashing via DFU requires [[http:// | + | For just flashing the latest version or for ocasional development flashing via DFU is good enough and does not required any additional hardware. |
- | To flash the firmware vis DFU, use | + | ===== Schematic ===== |
+ | Schematic of the Loco Positioning Node: | ||
