projects:virtualmachine:index [2015-04-09 19:46] arnaud [Bitcraze Virtual Machine] |
projects:virtualmachine:index [2016-06-14 16:00] macke |
+ | ====== Bitcraze Virtual Machine ====== | ||
+ | In order to easily get going with the development of Bitcraze projects we have pre-configured a virtual machine that can be imported into [[https:// | ||
+ | The virtual machine can also be imported into [[http:// | ||
+ | If you would like to create your own virtual machine instead of downloading ours, then have a look at [[projects: | ||
+ | **Please note:** All the instructions here (and on sub-pages) are always updated to match the latest available version of the VM and might not be valid for earlier versions. | ||
+ | ====== Download ====== | ||
+ | You can download the VM using one of the link below (torrents preferred): | ||
+ | * Bitcraze VM 2016-06 (torrent) ([[http:// | ||
+ | * Bitcraze VM 0.8 ([[http:// | ||
+ | ====== VM info ====== | ||
+ | The [[https:// | ||
+ | ====== HOW-TOs ====== | ||
+ | ===== Update all the projects ===== | ||
+ | If you would like to update to the latest version from GitHub for all the projects you can either use the short-cut on the desktop (//Update all projects//) or run the following command: | ||
+ | ===== Run the Crazyflie PC client ===== | ||
+ | If you would like to fly the Crazyflie then you should to the following: | ||
+ | * Insert the controller and Crazyradio and pass them to the VM. In VirtualBox this is done by right-clicking on the USB icon in the bottom left hand of the screen and selecting the Crazyradio and the controller | ||
+ | * Start the cfclient either by using the short-cut on the desktop (// | ||
+ | * Press the //Connect// button and select the URI starting with //radio// and then press //Connect// | ||
+ | **PLEASE NOTE:** If no controller is passed to VirtualBox the default controller will be the // | ||
+ | ===== Build the Crazyflie firmware ===== | ||
+ | Running the following commands will build the firmware which can be flashed with the wireless bootloader. For updating the Crazyflie use the resulting // | ||
+ | cd ~/ | ||
+ | make CLOAD=1 DEBUG=0 | ||
+ | ====== Tutorials ====== | ||
+ | [[projects: | ||
