In order to easily get going with the development of Bitcraze projects we have pre-configured a virtual machine that can be imported into Oracle VirtualBox. It contains pre-requisites needed for development and usage of the projects at Bitcraze.
If you would like to create your own virtual machine instead of downloading ours, then have a look at these intructions. NOTE: These instructions are deprecated since the VM is now created with a script instead. It's kept as referens for now.
You can download the VM using one of the link below (torrents preferred):
The GitHub repository for the Bitcraze VM contains information on how the machine is set up and what comes pre-installed.
If you would like to update to the latest version from GitHub for all the projects you can either use the short-cut on the desktop (Update all projects) or run the following command:
cd ~/projects/crazyflie-firmware make CLOAD=1 DEBUG=0
