doc:lps:tdoa3:protocol [2018-05-02 14:38] kristoffer |
doc:lps:tdoa3:protocol [2018-06-13 09:22] kristoffer |
Line 7: | Line 7: | ||
- | This page describes the [[doc: | ||
===== System architecture ===== | ===== System architecture ===== | ||
Line 27: | Line 25: | ||
- | Packet | + | Packet |
7 bytes | 7 bytes | ||
- | 8 bits 8 bits 32 bits 8 bits | + | 8 bits 8 bits 32 bits 8 bits |
- | Header | + | Header |
Line 46: | Line 44: | ||
Remote anchor data: | | Remote anchor data: | | ||
Line 60: | Line 58: | ||
* **rxTimeStamp: | * **rxTimeStamp: | ||
* **distance: | * **distance: | ||
+ | * **LPP data:** See [[doc: | ||
===== Tag implementation ===== | ===== Tag implementation ===== | ||
Line 65: | Line 64: | ||
A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the packet receive timestamps to calculate its position. | A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the packet receive timestamps to calculate its position. | ||
+ | ===== Trying it out ===== | ||
+ | See [[doc: |
