User Tools
Site Tools
doc:lps:tdoa3:protocol
Differences
Link to this comparison view
Next revision
Previous revision
doc:lps:tdoa3:protocol [2018-05-02 13:45]
doc:lps:tdoa3:protocol [2018-11-06 10:10]
Line 1: Line 1:
-====== TDoA Anchor protocol V3 (experimental) ======+====== TDoA Anchor protocol V3 ======
-<WRAP center round tip 80%> +===== Design goals =====
-**NOTE**+
-This is work in progress. The specifications on this page may change at any time without backwards compatibility.  +The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system can cover an (virtually) unlimited area. At any point in the covered area, 5-10 anchors should be within range of a Tag.
-</WRAP> +
-This page describes the [[doc:lps:tdoa3|TDoA]] anchor protocol V3. +
-===== System architecture ===== +
-The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system will be able to cover an (virtually) unlimited area. At any point in the covered area, 5-10 anchors should be within range a Tag. +
 Each anchor knows its own position in a global coordinate system and broadcasts this information in time stamped packets that are used by one or more Tags to estimate their position. Each anchor knows its own position in a global coordinate system and broadcasts this information in time stamped packets that are used by one or more Tags to estimate their position.
Line 20: Line 11:
 ===== Packet scheduling ===== ===== Packet scheduling =====
-Packets are transmitted at random times and collisions are handled by the system.+Packets are transmitted at random times and collisions are handled by the receiving party.
 ===== Packet format ===== ===== Packet format =====
-There is only one packet format. +<ditaa>
 +Packet    :         | Header | Remote anchor data | LPP data |
-<code c+                                  7 bytes
-typedef struct { +                     <-------------------------------------------
-    uint8_t id;            // The id of the remote anchor +                      8 bits   8 bits     32 bits       8 bits
-    uint8_t seq;           // Sequence number of latest packet received from the remote anchor +                     <------> <------> <-----------> <----------->
-    uint16_t distance;     // Time of flight between the current anchor and the remote anchor in radio timer ticks +                    +--------+--------+-------------+-------------+
-    uint32_t rxTimeStamp;  // Receive time stamp of latest packet from the remote anchor +Header    :          type  |  seq   | txTimeStamp | remoteCount |
-} __attribute__((packed)) remoteAnchorData_t;+                    +--------+--------+-------------+-------------+
-typedef struct { +
-  uint8_t type;            // 0x30 +                                            6 or 8 bytes
-  uint8_t seq;             // The sequence number of this packet +                     <---------------------------------------------------------->
-  uint32_t txTimeStamp;    /Transmission time of this packet+                      8 bits      1 bit      7 bits     32 bits     0 or 16 bits
 +Remote anchor data: |   id   | hasDistance |  seq   | rxTimeStamp |   distance   |
 +</ditaa>
-  uint8_t remoteCount;     // The number of slots in the following section that are populated with data +  * **Header**
-  remoteAnchorData_t remoteData[LOCODECK_NR_OF_TDOA3_ANCHORS]; +    * **type:** 0x30
-} __attribute__((packed)) rangePacket3_t; +    * **seq:** the sequence number of this packet 0 - 127
-</code>+    * **txTimeStamp:** transmission time of this packet
 +    * **remoteCount:** the number of slots in the Remote Anchor Data section that are populated with data, max 8
 +  * **Remote anchor data**
 +    * **id:** the id of the remote anchor
 +    * **hasDistance:** 1 = distance data is included in the remote anchor data, total length is 8 bytes, otherwise it is 6 bytes.
 +    * **seq:** sequence number of latest packet received from the remote anchor 0 - 127
 +    * **rxTimeStamp:** receive time stamp of latest packet from the remote anchor
 +    * **distance:** time of flight between the current anchor and the remote anchor in radio timer ticks
 +  * **LPP data:** See [[doc:lps:lpp#lpp_short_packets|LPP short packet description]]
 ===== Tag implementation ===== ===== Tag implementation =====
-A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the packet receive timestamps to calculate its position.+A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the timestamps when packets are received to calculate its position.
 +===== Calculating TDoA =====
 +[[doc:lps:tdoa:principles|Please see TDoA positioning principles]]
doc/lps/tdoa3/protocol.txt · Last modified: 2020-05-12 14:08 by kimberly
