NOTE
This is work in progress. The specifications on this page may change at any time without backwards compatibility.
This page describes the TDoA anchor protocol V3.
The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system will be able to cover an (virtually) unlimited area. At any point in the covered area, 5-10 anchors should be within range a Tag.
typedef struct { uint8_t id; // The id of the remote anchor uint8_t seq; // Sequence number of latest packet received from the remote anchor uint16_t distance; // Time of flight between the current anchor and the remote anchor in radio timer ticks uint32_t rxTimeStamp; // Receive time stamp of latest packet from the remote anchor } __attribute__((packed)) remoteAnchorData_t; typedef struct { uint8_t type; // 0x30 uint8_t seq; // The sequence number of this packet uint32_t txTimeStamp; // Transmission time of this packet uint8_t remoteCount; // The number of slots in the following section that are populated with data remoteAnchorData_t remoteData[LOCODECK_NR_OF_TDOA3_ANCHORS]; } __attribute__((packed)) rangePacket3_t;
A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the packet receive timestamps to calculate its position.
