projects:crazyflie2:expansionboards:bosch [2017-05-23 15:36] jan [Setting Up] |
projects:crazyflie2:expansionboards:bosch [2021-06-24 16:13] (current) kimberly |
| + | [[https:// | ||
| ====== Bosch Sensor Deck ====== | ====== Bosch Sensor Deck ====== | ||
| Line 7: | Line 13: | ||
| ===== Specification ===== | ===== Specification ===== | ||
| - | As there are different versions of the sensor deck, some sensors are only avaible | + | As there are different versions of the sensor deck, some sensors are only available |
| - | * Intertial | + | * Inertial |
| * [[https:// | * [[https:// | ||
| * triaxial 12-bit accelerometer (up to ± 16g) | * triaxial 12-bit accelerometer (up to ± 16g) | ||
| Line 55: | Line 61: | ||
| Now you are ready to make the firmware and flash it on your crazyflie. | Now you are ready to make the firmware and flash it on your crazyflie. | ||
| - | For evaluation purposes you might want to log sensors data what can be done with help of the [[projects: | + | For evaluation purposes you might want to log sensors data which can be done with help of the [[projects: |
