Bosch Sensortec expansion deck V2 schematic
SENSORS = bosch
static uint8_t gyroPrimInUse = SENSORS_BMI055; static uint8_t accelPrimInUse = SENSORS_BMI055;
Now you are ready to make the firmware and flash it on your crazyflie.
For evaluation purposes you might want to log sensors data what can be done with help of the Micro SD expansion deck.
