projects:crazyflie2:expansionboards:proto [2015-07-15 16:31] 127.0.0.1 external edit |
projects:crazyflie2:expansionboards:proto [2016-03-30 14:39] bjorn |
- | The prototype expansion board allows to prototype electronic | + | The prototyping deck allows to prototype electronic |
- | Both throw holes some smd components can be soldered to the board. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight. | + | Both through |
The two pad rows that are closest to the expansion connector are connected to the connectors. | The two pad rows that are closest to the expansion connector are connected to the connectors. | ||
Line 11: | Line 11: | ||
* Makes all 20 pins in the Crazyflie 2.0 expansion port available | * Makes all 20 pins in the Crazyflie 2.0 expansion port available | ||
- | * 40 pads for prototyping (supporting both though | + | * 40 pads for prototyping (supporting both through |
* Footprint for optional 1-wire memory (not mounted) | * Footprint for optional 1-wire memory (not mounted) | ||
* Mechanical specification: | * Mechanical specification: | ||
Line 19: | Line 19: | ||
===== Detection memory ===== | ===== Detection memory ===== | ||
- | If you want your prototype | + | If you want your prototype |
