projects:crazyflie2:expansionboards:proto
Prototype expansion board
The prototype expansion board allows to prototype electronic circuit to be attached on Crazylfie 2.0.
Both throw holes some smd components can be soldered to the board. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight.
Specification
  • Makes all 20 pins in the Crazyflie 2.0 expansion port available
  • 40 pads for prototyping (supporting both though hole and SMD components)
  • Footprint for optional 1-wire memory (not mounted)
  • Mechanical specification:
    • Weight: 1.5 g
    • Size (BxHxW): 28x28x4mm
Detection memory
If you want your prototype board to be detected automatically by the Crazyflie, for example to activate your driver code when the board is connected, you can solder a one-wire memory DS28E05 in the pads near P1 pin 10. For more information about the automatic expansion board detection see Crazyflie 2.0 onewwire expansion board detection.
projects/crazyflie2/expansionboards/proto.1436970671.txt.gz · Last modified: 2016-01-26 00:45 (external edit)
