User Tools
Site Tools
projects:crazyflie2:expansionboards:proto
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie2:expansionboards:proto [2016-01-26 00:47]
fred
projects:crazyflie2:expansionboards:proto [2021-06-24 16:12]
Line 1: Line 1:
-====== Prototype expansion board ======
-The prototype expansion board allows to prototype electronic circuits to be attached on Crazyflie 2.0.+<WRAP center round important 60%>
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]] or
 +[[https://www.bitcraze.io/documentation/repository/]]
 +</WRAP>
-Both through holes and SMD components can be soldered to the board. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight.+====== Prototyping deck ======
 +The prototyping deck allows electronic circuits to be attached on Crazyflie 2.0.
 +Both through holes and SMD components can be soldered to the deck. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight.
 The two pad rows that are closest to the expansion connector are connected to the connectors. The two pad rows that are closest to the expansion connector are connected to the connectors.
Line 19: Line 25:
 ===== Detection memory ===== ===== Detection memory =====
-If you want your prototype board to be detected automatically by the Crazyflie, for example to activate your driver code when the board is connected, you can solder a one-wire memory DS28E05 in the pads near P1 pin 10. For more information about the automatic expansion board detection see [[projects:crazyflie2:onewire|Crazyflie 2.0 onewire expansion board detection]]. +If you want your prototype deck to be detected automatically by the Crazyflie, for example to activate your driver code when the deck is connected, you can solder a one-wire memory DS28E05 in the pads near P1 pin 10.
projects/crazyflie2/expansionboards/proto.txt · Last modified: 2021-06-24 16:12 by kimberly
