The prototype expansion board allows to prototype electronic circuits to be attached on Crazyflie 2.0.
Both through holes and SMD components can be soldered to the board. The shape of the pads makes it possible to solder SMD capacitor and resistor which saves space and weight.
If you want your prototype board to be detected automatically by the Crazyflie, for example to activate your driver code when the board is connected, you can solder a one-wire memory DS28E05 in the pads near P1 pin 10. For more information about the automatic expansion board detection see Crazyflie 2.0 onewire expansion board detection.
