projects:crazyflie2:expansionboards:bosch [2017-05-23 10:23] jan |
projects:crazyflie2:expansionboards:bosch [2017-05-23 14:29] jan |
Line 3: | Line 3: | ||
Adds a variety of Bosch Sensortec sensors to the crazyflie2 | Adds a variety of Bosch Sensortec sensors to the crazyflie2 | ||
Line 10: | Line 10: | ||
* Intertial measurement units: | * Intertial measurement units: | ||
- | * closed loop | ||
* triaxial 12-bit accelerometer (up to ± 16g) | * triaxial 12-bit accelerometer (up to ± 16g) | ||
* triaxial 16 bit gyroscope (up to ± 2000°/s) | * triaxial 16 bit gyroscope (up to ± 2000°/s) | ||
- | * open loop | ||
* triaxial 16-bit accelerometer (up to ± 16g) | * triaxial 16-bit accelerometer (up to ± 16g) | ||
+ | * Accelerometer: | ||
+ | * BMA455 (V4) triaxial 16-bit accelerometer (up to ± 16g), upcoming sensor | ||
* Integrated environmental units: | * Integrated environmental units: | ||
Line 25: | Line 25: | ||
* Pressure sensors: | * Pressure sensors: | ||
+ | * [[https:// | ||
* Geomagnetic sensors: | * Geomagnetic sensors: | ||
Line 38: | Line 39: | ||
* Weight: | * Weight: | ||
* Size (WxHxD): 25.2x28.75x4mm³ | * Size (WxHxD): 25.2x28.75x4mm³ | ||
+ | ===== Schematic===== | ||
===== Setting Up ===== | ===== Setting Up ===== | ||
If not already done create config.mk in tools/make from [[https:// | If not already done create config.mk in tools/make from [[https:// | ||
- | Before make you may want to adjust which sensor should be used as gyro/accel. This can be done by changing | + | Before make you may want to adjust which sensor should be used as gyroscope |
<code c> | <code c> | ||
static uint8_t gyroPrimInUse = SENSORS_BMI055; | static uint8_t gyroPrimInUse = SENSORS_BMI055; | ||
static uint8_t accelPrimInUse = | static uint8_t accelPrimInUse = | ||
- | in [[https:// | + | in [[https:// |
Now you are ready to make the firmware and flash on your crazyflie. | Now you are ready to make the firmware and flash on your crazyflie. |
