SENSORS = bosch
Before make you may want to adjust which sensor should be used as gyro/accel. This can be done by changing
static uint8_t gyroPrimInUse = SENSORS_BMI055; static uint8_t accelPrimInUse = SENSORS_BMI055;
in sensors_bosch.c to any of the available sensors which fit in that slot.
Now you are ready to make the firmware and flash on your crazyflie.
