projects:crazyflie2:expansionboards:bosch
Bosch Sensor Deck
Adds a variety of Bosch Sensortec sensors to the crazyflie2
Specification
  • Intertial measurement units:
    • BMI055 (V1+V2+V4)
      • triaxial 12-bit accelerometer (up to ± 16g)
      • triaxial 16 bit gyroscope (up to ± 2000°/s)
    • BMI160 (V1+V2+V4)
      • triaxial 16-bit accelerometer (up to ± 16g)
  • Accelerometer:
    • BMA455 (V4) triaxial 16-bit accelerometer (up to ± 16g), upcoming sensor
  • Integrated environmental units:
    • BME680 (V1+V2)
      • Pressure
      • Relative humidity
      • Temperature
      • Gas (Volatile Organic Compounds)
  • Pressure sensors:
  • Geomagnetic sensors:
  • Smart hubs & ASSNs:
    • BMF055 (V1+V2+V4)
      • triaxial 14-bit accelerometer (up to ± 16g)
      • triaxial geomagnetic sensor
      • 32 bit Cortex M0+ microcontroller from Atmel
  • (1-wire memory for automatic expansion deck detection) not specified yet - coming soon
  • Mechanical specification:
    • Weight:
    • Size (WxHxD): 25.2×28.75x4mm³
Schematic
Setting Up
SENSORS = bosch
static uint8_t gyroPrimInUse =          SENSORS_BMI055;
static uint8_t accelPrimInUse =         SENSORS_BMI055;
Now you are ready to make the firmware and flash on your crazyflie.
projects/crazyflie2/expansionboards/bosch.1495542560.txt.gz · Last modified: 2017-05-23 14:29 by jan
