projects:crazyflie2:expansionboards:bosch [2017-05-23 14:29] jan |
projects:crazyflie2:expansionboards:bosch [2017-05-23 15:36] jan [Setting Up] |
====== Bosch Sensor Deck ====== | ====== Bosch Sensor Deck ====== | ||
- | Adds a variety of Bosch Sensortec sensors to the crazyflie2 | + | Adds a variety of Bosch Sensortec sensors to the crazyflie. |
Line 42: | Line 42: | ||
===== Schematic===== | ===== Schematic===== | ||
+ | Bosch Sensortec expansion deck V2 {{: | ||
===== Setting Up ===== | ===== Setting Up ===== | ||
If not already done create config.mk in tools/make from [[https:// | If not already done create config.mk in tools/make from [[https:// | ||
Line 52: | Line 53: | ||
in [[https:// | in [[https:// | ||
- | Now you are ready to make the firmware and flash on your crazyflie. | + | Now you are ready to make the firmware and flash it on your crazyflie. |
+ | For evaluation purposes you might want to log sensors data what can be done with help of the [[projects: |
