This howto is going to describe step-by-step how to make and flash your first Crazyflie 2.0 deck driver.
PROJ_OBJ_CF2 += hello.o
Decks can contain a memory that contains its name. In our case the hello driver would be initialised only when a deck identified as “myHello” is installed on the Crazyflie. For development purpose it is possible to force enabling a deck driver. To do so create the file tools/make/config.mk with the content:
$ make $ make cload
$ make (..) CC hello.o (...) Crazyflie 2.0 build! Build 44:61f3d878233d (2015.08.1-44) MODIFIED Version extracted from git Crazyloader build! text data bss dec hex filename 130660 1636 29828 162124 2794c cf2.elf rm version.c $ make cload ../crazyflie-clients-python/bin/cfloader flash cf2.bin stm32-fw Restart the Crazyflie you want to bootload in the next 10 seconds ... done! Connected to bootloader on Crazyflie 2.0 (version=0x10) Target info: nrf51 (0xFE) Flash pages: 232 | Page size: 1024 | Buffer pages: 1 | Start page: 88 144 KBytes of flash available for firmware image. Target info: stm32 (0xFF) Flash pages: 1024 | Page size: 1024 | Buffer pages: 10 | Start page: 16 1008 KBytes of flash available for firmware image. Flashing 1 of 1 to stm32 (fw): 161867 bytes (159 pages) ..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10.........9 Reset in firmware mode ... $
