doc:crazyflie:api:firmware:deck:howto
Making your first Deck driver
This howto is going to describe step-by-step how to make and flash your first Crazyflie 2.X deck driver. See the deck api documentation page for more information about the code.
Development environment
Writing the driver
hello.c
#include "debug.h"
#include "deck.h"
static void helloInit()
  DEBUG_PRINT("Hello Crazyflie 2.0 deck world!\n");
static bool helloTest()
  DEBUG_PRINT("Hello test passed!\n");
  return true;
  .name = "myHello",
  .init = helloInit,
  .test = helloTest,
DECK_DRIVER(helloDriver);
Adding the driver to the build
PROJ_OBJ += hello.o
Enabling the driver
config.mk
CFLAGS += -DDECK_FORCE=myHello
DEBUG=1
Note Each time you modify config.mk you should recompile the full firmware by cleaning up the build folder with 'make clean'
Compile, flash and run!
crazyflie-firmware$ make
  CC    hello.o
Crazyflie 2.0 build!
Build 44:61f3d878233d (2015.08.1-44) MODIFIED
Version extracted from git
Crazyloader build!
   text	   data	    bss	    dec	    hex	filename
 130660	   1636	  29828	 162124	  2794c	cf2.elf
rm version.c
../crazyflie-clients-python/bin/cfloader flash cf2.bin stm32-fw
 10 seconds ...
 done!
Connected to bootloader on Crazyflie 2.0 (version=0x10)
Target info: nrf51 (0xFE)
Target info: stm32 (0xFF)
Flashing 1 of 1 to stm32 (fw): 161867 bytes (159 pages) ..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10.........9
Reset in firmware mode ...
doc/crazyflie/api/firmware/deck/howto.1550738891.txt.gz · Last modified: 2019-02-21 09:48 by tobias
