doc:crazyflie:api:firmware:deck
Deck API
The Deck API allows to easily communicates with decks installed on the Crazyflie. The deck API is still in development, it will:
  • Enumerates installed Deck and initialize drivers (pretty much done)
  • Provides easy to use arduino-like API to access (started)
  • Optionally provides a task to run in (arduino-like setup and loop) (not started yet)
If you want to get started you can follow the howto to get your code running.
Deck drivers
Decks are enumerated automatically using a One Wire (OW) memory soldered on the deck PCB. The Deck driver API is using a declarative syntax to register deck drivers and initialize them when the proper deck is installed.
Minimal driver
This is a minimal deck driver, myled.c:
#include "deck.h"
void myledInit(DeckInfo *info)
  pinMode(DECK_GPIO_IO1, OUTPUT);     // Set my Led pin to output
  digitalWrite(DECK_GPIO_IO1, HIGH);  // Light it up
bool myledTest()
  return true;
const DeckDriver myled_driver = {
  .vid = 0,
  .pid = 0,
  .name = "meMyled",
  .usedGpio = DECK_USING_IO_1,
  .init = myledInit,
  .test = myledTest,
DECK_DRIVER(myled_driver);
  • At startup the decks are enumerated and if a deck has the name “meMyled”, it will be initialized.
  • Init is called on all initialized driver and then test is called.
  • The init and test functions are both optional (we have some board with only init and event some with only test). If absent just remove the .init or .test initialisation.
  • In this mode no task are created so to run some code at regular intervale the code needs to deal with freeRtos or with the other parts of the Crazyflie code.
To compile the driver, place it in deck/drivers/src/ and add it to the Makefile:
PROJ_OBJ += myled.o
Forcing initialization of a driver
The deck driver will be initialized only if a deck is connected with the right OW memory content. During development it is possible to force the initialisation of a deck by adding a define in ```tools/make/config.mk```:
CFLAGS += -DDECK_FORCE=meMyled
Driver declaration API
DECK_DRIVER(const struct DeckDriver)
To register a deck driver the DECK_DRIVER() macro should be called with a deck structure as argument.
DeckDriver structure
typedef struct deck_driver {
  /* Identification of the deck (written in the board) */
  uint8_t vid;
  uint8_t pid;
  char *name;
  /* Periphreal and Gpio used _dirrectly_ by the driver */
  uint32_t usedPeriph;
  uint32_t usedGpio;
  /* Init and test functions */
  void (*init)(struct deckInfo_s *);
  bool (*test)(void);
} DeckDriver;
doc/crazyflie/api/firmware/deck.txt · Last modified: 2020-05-12 14:23 by kimberly
