The library is asynchronous and based on callbacks for events. Functions like open_link will return immediately, and the callback connected will be called when the link is opened. The library doesn't contain any threads or locks that will keep the application running, it's up to the application that is using the library to do this.
The library supports setting up logging configurations that are used for logging variables from the firmware. Each log configuration contains a number of variables that should be logged as well as a time period (in ms) of how often the data should be sent back to the host. Once the log configuration is added to the firmware the firmware will automatically send back the data at every period. These configurations are used in the following way:
There's a few limitations that needs to be taken into account:
The library supports reading and writing parameters at run-time to the firmware. This is intended to be used for data that is not continuously being changed by the firmware, like setting regulation parameters and reading out if the power-on self-tests passed. Parameters should only change in the firmware when being set from the host or during start-up. The library doesn't continuously update the parameter values, this should only be done once after connecting. After each write to a parameter the firmware will send back the updated value and this will be forwarded to callbacks registered for reading this parameter. The parameters should be used in the following way:
All names of parameters and log variables use the same structure: group.name
The group should be used to bundle together logical groups, like everything that has to do with the stabilizer should be in the group stabilizer.
There's a limit of 28 chars in total and here are some examples:
All callbacks are handled using the Caller class that contains the following methods:
add_callback(cb) """ Register cb as a new callback. Will not register duplicates. """ remove_callback(cb) """ Un-register cb from the callbacks """ call(*args) """ Call the callbacks registered with the arguments args """
The library contains a special link driver, named DebugDriver. This driver will emulate a Crazyflie and is used for testing of the UI and library. Normally this will be hidden from the user except if explicitly enabled in the configuration file. The driver supports the following:
There are a number of different URIs that will be returned from the driver. These will have different functions, like always returning a random TOC CRC to always trigger TOC downloading or failing during connect. The driver also has support for sending back data with random delays to trigger random re-sending by the library.
Before the library can be used the link drivers have to he initialized. This will search for available drivers and instantiate them.
init_drivers(enable_debug_driver=False) """ Search for and initialize link drivers. If enable_debug_driver is True then the DebugDriver will also be used."""
Operations on the link and connection will return directly and will call the following callbacks when events occur:
# Called on disconnect, no matter the reason disconnected = Caller() # Called on unintentional disconnect only connection_lost = Caller() # Called when the first packet in a new link is received link_established = Caller() # Called when the user requests a connection connection_requested = Caller() # Called when the link is established and the TOCs (that are not cached) # have been downloaded connected = Caller() # Called if establishing of the link fails (i.e times out) connection_failed = Caller() # Called for every packet received packet_received = Caller() # Called for every packet sent packet_sent = Caller() # Called when the link driver updates the link quality measurement link_quality_updated = Caller()
crazyflie = Crazyflie() crazyflie.connected.add_callback(crazyflie_connected)
crazyflie = Crazyflie() crazyflie.connected.add_callback(crazyflie_connected) crazyflie.open_link("radio://0/10/250K")
Then you can use the following to close the link again:
crazyflie.close_link()
The control commands are not implemented as parameters, instead they have a special API.
send_setpoint(roll, pitch, yaw, thrust): """ Send a new control set-point for roll/pitch/yaw/thust to the copter The arguments roll/pitch/yaw/trust is the new set-points that should be sent to the copter """
Thrust is an integer value ranging from 10001 (next to no power) to 60000 (full power). Sending a command makes it apply for 500 ms, after which the firmware will cut out the power. With this in mind, you need to try and maintain a thrust level, with a tick being sent at least once every 2 seconds. Ideally you should be sending one tick every 10 ms, for 100 commands a second. This has a nice added benefit of allowing for very precise control.
param_name = "group.name" param_value = 3 crazyflie.param.set_value(param_name, param_value)
The parameter reading is done using callbacks. When a parameter is updated from the host (using the code above) the parameter will be read back by the library and this will trigger the callbacks. Parameter callbacks can be added at any time (you don't have to be connected to a Crazyflie).
add_update_callback(group, name=None, cb=None) """ Add a callback for a specific parameter name or group. If not name is specified then all parameters in the group will trigger the callback. This callback will be executed when a new value is read from the Crazyflie. """ request_param_update(complete_name) """ Request an update of the value for the supplied parameter. """ set_value(complete_name, value) """ Set the value for the supplied parameter. """
Here's an example of how to use the calls.
crazyflie.param.add_update_callback(group="group", name="name", param_updated_callback) def param_updated_callback(name, value): print "%s has value %d" % (name, value)
The API to create and get information from LogConfig:
# Called when new logging data arrives data_received_cb = Caller() # Called when there's an error error_cb = Caller() # Called when the log configuration is confirmed to be started started_cb = Caller() # Called when the log configuration is confirmed to be added added_cb = Caller() add_variable(name, fetch_as=None) """Add a new variable to the configuration. name - Complete name of the variable in the form group.name fetch_as - String representation of the type the variable should be fetched as (i.e uint8_t, float, FP16, etc) If no fetch_as type is supplied, then the stored as type will be used (i.e the type of the fetched variable is the same as it's stored in the Crazyflie).""" start() """Start the logging for this entry""" stop() """Stop the logging for this entry""" delete() """Delete this entry in the Crazyflie"""
The API for the log in the Crazyflie:
add_config(logconf) """Add a log configuration to the logging framework. When doing this the contents of the log configuration will be validated and listeners for new log configurations will be notified. When validating the configuration the variables are checked against the TOC to see that they actually exist. If they don't then the configuration cannot be used. Since a valid TOC is required, a Crazyflie has to be connected when calling this method, otherwise it will fail."""
logconf = LogConfig(name="Logging", period_in_ms=100) logconf.add_variable("group1.name1", "float") logconf.add_variable("group1.name2", "uint8_t") logconf.add_variable("group2.name1", "int16_t")
The datatype is the transferred datatype, it will be converted from internal type to transferred type before transfers:
# Callback called when the connection is established to the Crazyflie def connected(link_uri): crazyflie.log.add_config(logconf) if logconf.valid: logconf.data_received_cb.add_callback(data_received_callback) logconf.error_cb.add_callback(logging_error) logconf.start() else: print "One or more of the variables in the configuration was not found in log TOC. No logging will be possible." def data_received_callback(timestamp, data, logconf): print "[%d][%s]: %s" % (timestamp, logconf.name, data) def logging_error(logconf, msg): print "Error when logging %s" % logconf.name
The examples are now placed in the repository in the examples folder.
