| Port | Channel | Name |
| 7 | 0 | Generic setpoint |
| Byte | Value | Note |
| 0 | ID | ID of the setpoint packet |
| 1.. | Payload | Format defined per ID |
Defined IDs:
| ID | Type |
| 0 | stop |
| 1 | Velocity World |
Format:
struct velocityPacket_s { float vx; // m in the world frame of reference float vy; // ... float vz; // ... float yawrate; // rad/s } __attribute__((packed));
