| Port | Channel | Name |
| 7 | 0 | Generic setpoint |
| Byte | Value | Note |
| 0 | ID | ID of the setpoint packet |
| 1.. | Payload | Format defined per ID |
Defined IDs:
| ID | Type |
| 0 | stop |
| 1 | Velocity World |
| 2 | Z Distance |
Payload format:
struct velocityPacket_s { float vx; // m in the world frame of reference float vy; // ... float vz; // ... float yawrate; // deg/s } __attribute__((packed));
Set the Crazyflie absolute height and roll/pitch angles. Used for Z-ranger.
Payload format:
struct zDistancePacket_s { float roll; // deg float pitch; // ... float yawrate; // deg/s float zDistance; // m in the world frame of reference } __attribute__((packed));
