For more information on how to use this and how this is implemented have a look here.
| Port | Channel | Function |
| 5 | 0 | Table of content access: Used for reading out the TOC |
| 5 | 1 | Log control: Used for adding/removing/starting/pausing log blocks |
| 5 | 2 | Log data: Used to send log data from the Crazyflie to the client |
This channel is used to download the Table Of Contents that contains all the variables that are available for logging and what types they are.
Request (PC to Copter):
| GET_ITEM (0) | ID |
Length 1 1
Answer (Copter to PC):
| 0 | GET_ITEM | At 0 for GET_ITEM operation |
| 1 | ID | ID of the item to be retrieved. The variables are numbered from 0 to LOG_LEN (see GET_INFO command) |
| 0 | GET_ITEM | 0 for GET_ITEM operation |
| 1 | ID | ID of the item returned |
| 2 | Type | Variable type of the element. See variable types list |
| 3.. | Group | Null-terminated string containing variable group |
| .. | Name | Null-terminated string containing the variable name |
| GET_INFO (1) |
Length 1
Length 1 1 4 1 1
| 0 | GET_INFO | At 1 for GET_INFO operation |
| 0 | GET_INFO | 1 for GET_INFO operation |
| 1 | LOG_LEN | Number of log items contained in the log table of content |
| 2 | LOG_CRC | CRC values of the log TOC memory content. This is a fingerprint of the copter build that can be used to cache the TOC |
| 6 | LOG_MAX_PACKET | Maximum number of log packets that can be programmed in the copter |
| 7 | LOG_MAX_OPS | Maximum number of operation programmable in the copter. An operation is one log variable retrieval programming |
| Control command byte | Command | Operation |
| 0 | CREATE_BLOCK | Create a new log block |
| 1 | APPEND_BLOCK | Append variables to an existing block |
| 2 | DELETE_BLOCK | Delete log block |
| 3 | START_BLOCK | Enable log block transmission |
| 4 | STOP_BLOCK | Disable log block transmission |
| 5 | RESET | Delete all log blocks |
The log data channel is used by the copter to send the log blocks at the programmed rate. The packet format is
| BLOCK_ID | TIME_STAMP | LOG VARIABLE VALUES |
Length 1 3 0 to 28
| 0 | BLOCK_ID | ID of the block |
| 1 | ID | Timestamp in ms from the copter startup as a little-endian 3 bytes integer |
| 4.. | Log variable values | Packed log values in little endian format |
