Memory access is not used for the Crazyflie Nano Quadcopter, it's currently only implemented in the Crazyflie 2.0. Using the memory access gives the possibility to:
Currently the following memories are supported:
There's more information available for how the EEPROM is structured and how the 1-wire memories work and are structured.
Getting information and reading/writing the memories is optional for the clients, but the -Crazyflie Python Client- always downloads information about the memories on connect.
The memory port uses 3 different channels:
| Port | Channel | Function |
| 4 | 0 | Get information about amount and types of memory as well as erasing |
| 4 | 1 | Read memories |
| 4 | 2 | Write memories |
This channel is used to get the number of memories present, information about the memories and the possibility to mass erase memories. The first byte of every packet is a command byte:
| Command byte | Command | Operation |
| 1 | GET_NBR_OF_MEMS | Get the number of memories |
| 2 | GET_MEM_INFO | Get information about a memory |
| 3 | SET_MEM_ERASE | Mass erase a memory |
This command is used to get the number of memories present.
The request from host to Crazyflie:
| Byte | Field | Value | Length | Comment |
| 0 | GET_NUMBER_OF_MEMS | 0x01 | 1 | The command byte |
Reply from Crazyflie to host:
| 1 | Number of memories | 1 | The number of memories preset (all types) |
Example where there are 3 memories present on the Crazyflie:
Host-to-Crazyflie: <port/chan> 0x01 Crazyflie-to-Host: <port/chan> 0x01 0x03
This command is used to get information about a memory give it's id. The id of memories is sequential and is from 0 to one less than the returned number of memories from GET_NUMBER_OF_MEMS.
| 0 | GET_MEM_INFO | 0x02 | 1 | The command byte |
| 1 | MEM_ID | 1 | A memory id that is 0 ⇐ id < NBR_OF_MEMS |
Reply from Crazyflie to host if the id is valid:
| 1 | MEM_ID | 1 | The memory id | |
| 2 | MEM_TYPE | 1 | The memory type (see below) | |
| 3 | MEM_SIZE | 4 | The size in bytes of the memory | |
| 7 | MEM_ADDR | 8 | The address of the memory (only valid for 1-wire memories) |
Where the MEM_TYPE field is:
| MEM_TYPE | Memory type | Comment |
| 0 | I2C | |
| 1 | 1-wire |
Reply from Crazyflie to host if the id is not valid:
Example of requesting the information for a 1-wire memory with MEM_ID=1, MEM_SIZE=112bytes, MEM_ADDR=0x1234567890ABCDEF
Host-to-Crazyflie: <port/chan> 0x02 0x01 0x01 Crazyflie-to-Host: <port/chan> 0x02 0x01 0x01 0x70 0x00 0x00 0x00 0xEF 0xCD 0xAB 0x90 0x78 0x56 0x34 0x12
Example of requesting the information for a memory index that is not valid
Host-to-Crazyflie: <port/chan> 0x01 0x10 Crazyflie-to-Host: <port/chan> 0x01 0x10
This command is used to mass erase a memory with a given id. The id of memories is sequential and is from 0 to one less than the returned number of memories from GET_NUMBER_OF_MEMS.
| 0 | SET_MEM_ERASE | 0x03 | 1 | The command byte |
| 2 | STATUS | 1 | The status of the command (see below) |
Example of requesting a mass erase for a memory with MEM_ID=2
Host-to-Crazyflie: <port/chan> Crazyflie-to-Host: <port/chan>
Example of
This channel is only used to read memories and therefore the messages do not contain any command byte.
| 0 | MEM_ID | 1 | A memory id that is 0 ⇐ id < NBR_OF_MEMS | |
| 1 | MEM_ADDR | 4 | The address where the first byte should be read | |
| 5 | LEN | 1 | The number of bytes to be read |
Reply from Crazyflie to host if memory id is valid and the address and length to be read is valid:
| 5 | STATUS | 1 | The status of the request (see below) | |
| 6 | DATA | 1..24? | The data that was read (only if MEM_ID/MEM_ADDR/LEN is valid) |
Where the STATUS field is:
| STATUS | Comment |
| 0 | … |
| 1 | …. |
Example of reading LEN=0x0F bytes from MEM_ID=0x01 MEM_ADDR=0x0A
Host-to-Crazyflie: <port/chan> 0x01 0x0A 0x00 0x00 0x00 0x0F Crazyflie-to-Host: <port/chan> 0x01 0x0A 0x00 0x00 0x00 0x00 0x01 0x09 0x62 0x63 0x4C 0x65 0x64 0x52 0x69 0x6E 0x67 0x02 0x01 0x62 0x55
This channel is only used to write memories and therefore the messages do not contain any command byte.
| 5 | DATA | 1..24? | The data to be written |
Reply from Crazyflie to host if memory id is valid and the address and length to be written is valid:
| 4 | STATUS | 1 | The status of the request (see below) |
| STATUS | Comment |
| 0 | … |
| 1 | …. |
Example
