doc:crazyflie:dev:env:windows
Windows Development Environment
  • Using windows 10 – no technical reason why this wouldn't work on Windows 7, 8, or 8.1 though.
  • Whenever presented with a choice, x86 versions of the tools were chosen. It's important to keep this consistent since and x86 emulator wont' be able to call amd64 binaries, etc. Using all AMD64 should technically work, though.
  • Cygwin was chosen for a unix environment since it's probably the most common option out there. As stated below, MinGW is probably the best option because it's extremely lightweight and really all you need are a small handful of unix tools.
GNU/Linux Toolchain replacements
  • Make
  • Git
  • Tar (used in the crazyflie2-nrf-firmware project to unzip the nordic SDK)
  • Unzip (used in the crazyflie2-nrf-firmware project to unzip the nordic SDK)
  • Wget (used in the crazyflie2-nrf-firmware project to download the nordic SDK)
Option #1: Cygwin
Option #2: MinGW
Option #2.5: Ubuntu on Bash on Windows
Windows 10 supports (in beta) the ability to run an Ubuntu based bash shell natively, including apt-get and things you'd expect on normal Ubuntu. This is only a half-option for now: The main drawback is that hardware support (the crazyradio, for example) is not plumbed through to this shell, so you won't be able to flash, connect, or run the python tools which talk to hardware. Details here: https://msdn.microsoft.com/en-us/commandline/wsl/about
ARM Toolchain
  • Change the default install location to something without spaces
  • Choose “add to path” so it can be invoked from cmd or cygwin.
Java
Python Environment
Python Installation
Other Python Tools
PYQT4 for cfclient UI
SDL2.0
NumPy
Setup
Add both Python.exes to your path
ln -s /cygdrive/c/Python34/python.exe /usr/bin/python3
ln -s /cygdrive/c/Python27/python.exe /usr/bin/python2
Configure Python 3.4
Python3 -m pip install --upgrade pip
python3 -m pip install pyusb==1.0.0b2 pyzmq pysdl2 pyqtgraph
Python3 -m pip install <path to the NumPy .whl file you downloaded earlier
Setting up USB devices (CrazyRadio or Crazyflie via USB)
  1. Get Zadig from: http://zadig.akeo.ie/
  2. Run zadig.exe
  3. Choose the device (Radio or crazyflie)
  4. Choose and install the libusb-win driver
Clone the repos
mkdir ~/projects
cd ~/projects
git clone git://github.com/bitcraze/crazyflie-clients-python.git
git clone git://github.com/bitcraze/crazyflie-firmware.git
git clone git://github.com/bitcraze/crazyflie-bootloader.git
git clone git://github.com/bitcraze/crazyradio-firmware.git
git clone git://github.com/bitcraze/crazyflie2-stm-bootloader.git
git clone git://github.com/bitcraze/crazyflie2-nrf-bootloader.git
git clone git://github.com/bitcraze/crazyflie2-nrf-firmware.git
OpenOCD
IDE Setup
Eclipse
  • Import the project you are interested in by selecting File→New project and C/C++→C project
  • Configure the project to use the already cloned code in the project directory by setting the following settings:
    • Project name: <same as the directory in projects>
    • Use default location: False
    • Location: <path to where you cloned the repo>/<project>
    • Project type: Makefile project → Empty project
    • Toolchains: – Other Toolchain –
PyCharm
Visual Studio
doc/crazyflie/dev/env/windows.1467283632.txt.gz · Last modified: 2016-06-30 12:47 by theseankelly
