As stated earlier, this guide was written using Cygwin. There may be a couple missing steps here and there if you want to go with MinGW, but nothing major. Please update the wiki if you choose MinGW and find anything missing!
Windows 10 supports (in beta) the ability to run an Ubuntu based bash shell natively, including apt-get and things you'd expect on normal Ubuntu. This is only a half-option for now: The main drawback is that hardware support (the crazyradio, for example) is not plumbed through to this shell, so you won't be able to flash, connect, or run the python tools which talk to hardware.
Details here: https://msdn.microsoft.com/en-us/commandline/wsl/about
Install the latest from https://riverbankcomputing.com/software/pyqt/download Get the version for python 3.4
