This procedure has been tested on a just-installed Yosemite installation. Commands in code blocks have to be executed in a terminal window.
Download and install macport installer from https://www.macports.org/install.php
Install the command line developer tools:
xcode-select --install
I found that installing only the command line developer tools is enough for Crazyflie client dependencies. However installing Xcode seems to be recommended. I installed the command line developer tools:
Update mac ports
sudo port selfupdate
Update already installed ports (none on a fresh installation)
sudo port upgrade outdated
Install Crazyflie client dependencies
sudo port install libusb python27 py27-pyusb py27-SDL2 py27-pyqt4
Most but not all packages are pre-compiled so this installation takes some time. It took about 12 minutes for me, YMMV.
Now you are able to clone and run the Crazyflie client!
cd Documents git clone https://github.com/bitcraze/crazyflie-clients-python cd crazyflie-clients-python /opt/local/bin/python2.7 bin/cfclient
If you want to use the plotter tab, to graph in real time Crazyflie log variables, you need to install pyqtgraph. It installs a lot of dependencies and took about 5 minutes (The ports install time varies a lot depending on how many ports are pre-compiled):
sudo port install py27-pyqtgraph
You can now access the plotter tab:
