doc:crazyradio:usb:index
USB and Radio protocol of the Crazyradio dongle
This page documents the protocol used in version 0.52 of the Crazyradio dongle. Future version (up to 1.0) will be kept compatible.
Radio configuration
Crazyradio is configured in PTX mode. It can communicate with Nordic chips compatible with the nrf24L family (at least nrf24L01p, nRF51 and nRF52 tested). In order to communicate with the Crazyradio the target has to be configure correctly:
  • PRX mode
  • One active pipe with the address configured in the Crazyradio dongle, by default it is 0xE7E7E7E7E7
  • 5 byte address
  • Dynamic payload length enable
  • Payload with ack enable
The Crazyflie is already configured that way. The relevant source code can be seen in radiolink.c.
USB protocol
EP0 Control Control endpoint. Used to configure the dongle
EP1IN/OUT Bulk Data endpoints. Used to send and receive radio packets
Data transfer
  • Send the packet to EP1_OUT. Its length should be between 1 to 32 Bytes
  • Read the ACK from EP1_IN. The first byte is the transfer status and the following bytes are the content of the ACK payload, if any.
Status Bit Role
4..7 Number of retransmission
2..3 Reserved
1 Power detector
0 ACK received
Dongle configuration and functions summary
bmRequestType bRequest wValue wIndex wLength data
0x40 SET_RADIO_CHANNEL (0x01) channel Zero Zero None
0x40 SET_RADIO_ADDRESS (0x02) Zero Zero 5 Address
0x40 SET_DATA_RATE (0x03) Data rate Zero Zero None
0x40 SET_RADIO_POWER (0x04) Power Zero Zero None
0x40 SET_RADIO_ARD (0x05) ARD Zero Zero None
0x40 SET_RADIO_ARC (0x06) ARC Zero Zero None
0x40 ACK_ENABLE (0x10) Active Zero Zero None
0x40 SET_CONT_CARRIER (0x20) Active Zero Zero None
0x40 START_SCAN_CHANNELS (0x21) Start Stop Length Packet
0xC0 GET_SCAN_CHANNELS (0x21) Zero Zero 63 Result
0x40 LAUNCH_BOOTLOADER (0xFF) Zero Zero Zero None
Set radio channel
Set radio address
Addresses where the level shifts only one time (that is, 000FFFFFFF) can often be detected in
noise and can give a false detection, which may give a raised Packet-Error-Rate. Addresses
as a continuation of the preamble (hi-low toggling) raises the Packet-Error-Rate.
Set data rate
Value Radio data rate
0 250Kbps
1 1MBps
2 2Mbps (Default)
Set radio power
Value Power
0 -18dBm
1 -12dBm
2 -6dBm
3 0dBm
Configure auto retry (ARD/ARC)
Possible values for ARD:
Value ARD wait time
0x00 250us
0x01 500us
0x0F 4000us
Value ACK payload length
0x80 0Byte
0x81 1Byte
0xA0 32Bytes
Auto ACK configuration
Active values Meaning
0 Auto ACK deactivated
Not 0 Auto ACK enable (default)
Continuous carrier mode
0 Dongle working normally (default)
Not 0 Dongle in continuous carrier mode
Channels scanning
0xC0 GET_SCAN_CHANNELS (0x21) Zero Zero 64 Result
Note After scanning, the channel will be set to the last scanned channel.
Warning On some platform, an empty scan will return a buffer of 64 bytes. This is though to be a USB host implementation bug, see ticket #9 in the Crazyradio firmware project. If a buffer of more than 63 bytes is returned, it means that no channel have been received.
Launch bootloader
Radio protocol
doc/crazyradio/usb/index.txt · Last modified: 2020-05-12 12:12 by kimberly
