EP0 | Control | Control endpoint. Used to configure the dongle |
EP1IN/OUT | Bulk | Data endpoints. Used to send and receive radio packets |
Status Bit | Role |
4..7 | Number of retransmition |
2..3 | Reserved |
1 | Power detector |
0 | Ack received |
bmRequestType | bRequest | wValue | wIndex | wLength | data |
0x40 | SET_RADIO_CHANNEL (0x01) | channel | Zero | Zero | None |
0x40 | SET_RADIO_ADDRESS (0x02) | Zero | Zero | 5 | Address |
0x40 | SET_DATA_RATE (0x03) | Datarate | Zero | Zero | None |
0x40 | SET_RADIO_POWER (0x04) | Power | Zero | Zero | None |
0x40 | SET_RADIO_ARD (0x05) | ARD | Zero | Zero | None |
0x40 | SET_RADIO_ARC (0x06) | ARC | Zero | Zero | None |
0x40 | ACK_ENABLE (0x10) | Active | Zero | Zero | None |
0x40 | SET_CONT_CARRIER (0x20) | Active | Zero | Zero | None |
0x40 | LAUNCH_BOOTLOADER (0xFF) | Zero | Zero | Zero | None |
The radio channel is set as soon as the setup transaction is completed which takes about 1ms. The new frequency is going to be used for the following transfered packets. Default value for the radio channel is 2.
Value | Radio datarate |
0 | 250Kbps |
1 | 1MBps |
2 | 2Mbps (Default) |
Possible values for ARD:
Value | ARD wait time |
0x00 | 250us |
0x01 | 500us |
0x0F | 4000us |
Value | Ack payload length |
0x80 | 0Byte |
0x81 | 1Byte |
0xA0 | 32Bytes |
Active values | Meaning |
0 | Auto ack deactivated |
Not 0 | Auto ack enable (default) |
0 | Dongle working normally (default) |
Not 0 | Dongle in continuous carrier mode |
