This page documents the protocol used in version 0.52 of the Crazyradio dongle. Future version (up to 1.0) will be kept compatible.
Crazyradio is configured in PTX mode. It can communicate with Nordic chips of the nrf24L family (at least nrf24L01p tested). In order to communicate with the Crazyradio the target has to be configure correctly:
The Crazyflie is already configured that way. The relevant source code can be seen in radiolink.c.
EP0 | Control | Control endpoint. Used to configure the dongle |
EP1IN/OUT | Bulk | Data endpoints. Used to send and receive radio packets |
Status Bit | Role |
4..7 | Number of retransmission |
2..3 | Reserved |
1 | Power detector |
0 | ACK received |
bmRequestType | bRequest | wValue | wIndex | wLength | data |
0x40 | SET_RADIO_CHANNEL (0x01) | channel | Zero | Zero | None |
0x40 | SET_RADIO_ADDRESS (0x02) | Zero | Zero | 5 | Address |
0x40 | SET_DATA_RATE (0x03) | Data rate | Zero | Zero | None |
0x40 | SET_RADIO_POWER (0x04) | Power | Zero | Zero | None |
0x40 | SET_RADIO_ARD (0x05) | ARD | Zero | Zero | None |
0x40 | SET_RADIO_ARC (0x06) | ARC | Zero | Zero | None |
0x40 | ACK_ENABLE (0x10) | Active | Zero | Zero | None |
0x40 | SET_CONT_CARRIER (0x20) | Active | Zero | Zero | None |
0x40 | START_SCAN_CHANNELS (0x21) | Start | Stop | Length | Packet |
0xC0 | GET_SCAN_CHANNELS (0x21) | Zero | Zero | 63 | Result |
0x40 | LAUNCH_BOOTLOADER (0xFF) | Zero | Zero | Zero | None |
Value | Radio data rate |
0 | 250Kbps |
1 | 1MBps |
2 | 2Mbps (Default) |
Value | Power |
0 | -18dBm |
1 | -12dBm |
2 | -6dBm |
3 | 0dBm |
Possible values for ARD:
Value | ARD wait time |
0x00 | 250us |
0x01 | 500us |
0x0F | 4000us |
Value | ACK payload length |
0x80 | 0Byte |
0x81 | 1Byte |
0xA0 | 32Bytes |
Active values | Meaning |
0 | Auto ACK deactivated |
Not 0 | Auto ACK enable (default) |
0 | Dongle working normally (default) |
Not 0 | Dongle in continuous carrier mode |
Note: After scanning, the channel will be set to the last scanned channel.
