This page documents the protocol used in version 0.52 of the Crazyradio dongle. Future version (up to 1.0) will be kept compatible.
Crazyradio is configured in PTX mode. It can communicate with Nordic chips compatible with the nrf24L family (at least nrf24L01p, nRF51 and nRF52 tested). In order to communicate with the Crazyradio the target has to be configure correctly:
The Crazyflie is already configured that way. The relevant source code can be seen in radiolink.c.
| Status Bit | Role |
| 4..7 | Number of retransmission |
| 2..3 | Reserved |
| 1 | Power detector |
| 0 | ACK received |
| 0x40 | SET_DATA_RATE (0x03) | Data rate | Zero | Zero | None |
| 0x40 | START_SCAN_CHANNELS (0x21) | Start | Stop | Length | Packet |
| 0xC0 | GET_SCAN_CHANNELS (0x21) | Zero | Zero | 63 | Result |
| Value | Radio data rate |
| 0 | 250Kbps |
| 1 | 1MBps |
| 2 | 2Mbps (Default) |
| Value | Power |
| 0 | -18dBm |
| 1 | -12dBm |
| 2 | -6dBm |
| 3 | 0dBm |
Possible values for ARD:
| Value | ARD wait time |
| 0x00 | 250us |
| 0x01 | 500us |
| 0x0F | 4000us |
| Value | ACK payload length |
| 0x80 | 0Byte |
| 0x81 | 1Byte |
| 0xA0 | 32Bytes |
| Active values | Meaning |
| 0 | Auto ACK deactivated |
| Not 0 | Auto ACK enable (default) |
| 0xC0 | GET_SCAN_CHANNELS (0x21) | Zero | Zero | 64 | Result |
Note After scanning, the channel will be set to the last scanned channel.
Warning On some platform, an empty scan will return a buffer of 64 bytes. This is though to be a USB host implementation bug, see ticket #9 in the Crazyradio firmware project. If a buffer of more than 63 bytes is returned, it means that no channel have been received.
