Sent to the bootloader:
| Byte # | Value | Note |
| 0 | 0x00 | Boot command |
The SPI exchange command execure one SPI transaction. On the SPI bus it asserts the CS pin, sends WLEN bytes and then receives RLEN bytes.
| 1-2 | WLEN | Write length |
| 3-4 | RLEN | Read length |
Received from the bootloader:
