Sent to the bootloader:
| Byte # | Value | Note |
| 0 | 0x00 | Boot command |
The SPI exchange command execure one SPI transaction. On the SPI bus it asserts the CS pin, sends WLEN bytes and then receives RLEN bytes.
| 1-2 | WLEN | Write length |
| 3-4 | RLEN | Read length |
Received from the bootloader:
The write protection is implemented by setting the SR1 register in the SPI flash memory. This means that it can be disabled by clearing the SR1 register if updating the bootloader is required.
