There is two UARTs on the deck, UART0 on the Crazyflie deck interface and UART1 on 2.54mm soldering pads available for external communication. The bootloader is available on both UARTs. The UARTs are setup with a baudrate of 113200, one stop bit, no parity.
Warning: Version 1 of the bootloader has a bug that makes its baudrate be ~113200 instead of 115200 baud. This is a non-standard baudrate, it has been tested that using an FTDI USB-to-UART adapter setting a baudrate of 113200 works fine.
All numbers are encoded in little endian.
Sent to the bootloader:
| Byte # | Value | Note |
| 0 | 0x00 | Boot command |
| 1-2 | WLEN | Write length |
| 3-4 | RLEN | Read length |
Received from the bootloader:
| 0 | 0x02 | Get version command |
| 0 | 0x01 | Bootloader version |
The firmware is an iCE40 bitstream 1). The bitstream start with the bytes 0xff 0x00 followed by a null terminated string and then 0x00 0xff. This null terminated string is a comment. In the Lighthouse deck this comment is used to store the version of the firmware as a version string. The intention is that the deck user (ie. the Crazyflie or other external board) must be able to find-out if the firmware is compatible or if it needs to be upgraded or downgraded.
The version string format is a base 10 integer number in ascii indicating the version. For example “1”. It follows the rules of the C function strtol() to be decoded so the string can start with white-space, followed by an optional “+” or “=” followed by decimal digits. The decoding stops at the first non-digit character.
