doc:lps:twr-tdma
TWR-TDMA
Abstract
TWR-TDMA is implementing this concurrent mode using a Time Division Multiple Access algorithm. To do so, we define a time slot width and number of time slot per frame. Each tag is assigned a time slot and is only allowed to communicate in its assigned time slot. All the tags are synchronized on the Anchor 0 clock, they use it to calculate the position, in time, of the time slots.
Compiling Crazyflie for TWR-TDMA ranging
LPS_TDMA_ENABLE=1
CFLAGS += -DTDMA_NSLOTS_BITS=1
# CFLAGS += -DTDMA_SLOT=0        # Optional, see bellow
  • LPS_TDMA_ENABLE=1 Enable the TDMA mode for TWR
  • TDMA_NSLOTS_BITS=1 Configures 2 time slot (good for 2 tags). The number of time slot is 2^TDMA_NSLOTS_BITS
  • TDMA_SLOT Optionally hardcode the time slot. See bellow for time slot auto-configuration.
Configuring time slots
System performance
TWR-TDMA is currently implemented with time slots of 4ms. Each time slot is used by one tag to range with one anchor. This means that the ranging rate is of 1/(0.004 * 2^TDMA_NSLOTS_BITS) and the rate of update of the full system is 1/(0.004 * 2^TDMA_NSLOTS_BITS * nAnchors) where nAnchors is the number of anchors in the system.
The more timeslots, the less often measurements can be used to estimate the tag position and so the performance of the position estimate will deteriorate. For a great number of tag the TDoA mode is better suited.
doc/lps/twr-tdma.1500385283.txt.gz · Last modified: 2017-07-18 15:41 by arnaud
