| Physical position | Average estimated position | Std deviation of estimated position | ||||||
| X | Y | Z | X | Y | Z | X | Y | Z |
| 1.62 | 3.15 | -0.15 | 1.66 | 3.18 | 0.29 | 0.014 | 0.0097 | 0.0061 |
| 2.95 | 0.00 | -0.15 | 2.80 | 0.12 | 0.16 | 0.0072 | 0.010 | 0.0053 |
| 1.62 | 3.15 | 1.44 | 1.56 | 3.02 | 1.37 | 0.020 | 0.0066 | 0.016 |
| 1.62 | 4.80 | 1.44 | 1.67 | 4.64 | 1.40 | 0.013 | 0.0093 | 0.013 |
