misc:investigations:lps-precision
Measurements of accuracy and precision of the Loco Positioning system
The reference system
The results
Physical position Average estimated position Std deviation of estimated position
X Y Z X Y Z X Y Z
1.62 3.15 -0.15 1.66 3.18 0.29 0.014 0.0097 0.0061
2.95 0.00 -0.15 2.80 0.12 0.16 0.0072 0.010 0.0053
1.62 3.15 1.44 1.56 3.02 1.37 0.020 0.0066 0.016
1.62 4.80 1.44 1.67 4.64 1.40 0.013 0.0093 0.013
misc/investigations/lps-precision.1490343117.txt.gz · Last modified: 2017-03-24 09:11 by kristoffer
