misc:investigations:lps-precision
Measurements of accuracy and precision of the Loco Positioning system
Multiple measurements in reference system
The reference system
The results
Physical position Average estimated position Std deviation of estimated position
X Y Z X Y Z X Y Z
1.62 3.15 -0.15 1.66 3.18 0.29 0.014 0.0097 0.0061
2.95 0.00 -0.15 2.80 0.12 0.16 0.0072 0.010 0.0053
1.62 3.15 1.44 1.56 3.02 1.37 0.020 0.0066 0.016
1.62 4.80 1.44 1.67 4.64 1.40 0.013 0.0093 0.013
Measurement of accuracy and noise of 3D estimate and ranges
Setup
The system is setup with 6 anchors and one Crazyflie ranging in two-way-ranging mode.
Anchor positions
Anchor X Y Z
0 3.01 0.57 2.5
1 3.01 2.63 2.5
2 6.53 2.27 2.84
3 6.53 0.51 2.84
4 2.91 0.86 0.16
5 6.95 2.32 0.16
misc/investigations/lps-precision.1493911535.txt.gz · Last modified: 2017-05-04 17:25 by arnaud
