The system is setup with 6 anchors and one Crazyflie ranging in two-way-ranging mode.
| Anchor | X | Y | Z |
| 0 | 3.01 | 0.57 | 2.5 |
| 1 | 3.01 | 2.63 | 2.5 |
| 2 | 6.53 | 2.27 | 2.84 |
| 3 | 6.53 | 0.51 | 2.84 |
| 4 | 2.91 | 0.86 | 0.16 |
| 5 | 6.95 | 2.32 | 0.16 |
Physical distances from Crazyflie to anchors, calculated from positions
| Anchor | Distance |
| 0 | 2.80 |
| 1 | 2.87 |
| 2 | 2.69 |
| 3 | 2.77 |
| 4 | 2.27 |
| 5 | 2.20 |
