Electrical specification:
Mechanical specification:
Package contents:
Currently there is only a basic setup but as the developments advance so will the documentation. Start by mounting the big quad deck on the frame. After that connect the ESCs according to the diagrams below.
The BigQuad deck contains a 1-wire memory so it can be automatically detected and functions initialized. However as this currently is an ongoing development and a bigger quads ads a new level of caution we have decided to not enable the functionality by default. Therefore the firmware needs to be compiled with the BigQuad flag set to enable.
CFLAGS += -DENABLE_BQ_DECK
