BigQuad expansion deck
Specification
  • 4 x ESC connectors
    • CPPM input (3 pin)
    • GPS input (4 pin)
    • I2C expansion (4 pin)
    • Buzzer output (2 pin)
Electrical specification:
Mechanical specification:
  • Weight: 3.8g
  • Size (WxHxD): 36x40x5mm
Package contents:
  • 1 x BigQuad deck
  • 4 x M2x4 nylon screw
  • 2 x M2x6 hex spacer
Schematic
Setting up
Currently there is only a basic setup but as the developments advance so will the documentation. Start by mounting the big quad deck on the frame. After that connect the ESCs according to the diagrams below.
Basic connection diagram
Basic connection picture
Attaching the Crazyflie 2.0
If the frame allows the Crazyflie 2.0 motors to be kept mounted but it is fine to remove them as well. Attach and connect the Crazyflie 2.0 using either the long or short deck pins. Use the included nylon spacer and screws to secure the Crazyflie 2.0 in place and to keep it level.
Building Firmware
Enable BigQuad features
CFLAGS += -DENABLE_BQ_DECK
Current (2016-03) status notes
  • When the BQ-Deck is detected it will automatically switch to brushless motor drivers. It will be noted in the cfclient console if it detected it or not.
  • Different PID tuning parameters might be needed for it to fly well. Currently this has to be hard coded. Later this will be saved in the eeprom or in the 1-wire memory.
  • External battery voltage/current reading is implemented but no logic behind it, don't run out of battery. You can connect the cable (MON port) and watch the log variable.
  • The PWM output is set to 400Hz. Use ESC which can handle this or compile with new value.
Reference setup
projects/crazyflie2/expansionboards/bigquad.1457525711.txt.gz · Last modified: 2016-03-09 13:15 by tobias
