Electrical specification:
Mechanical specification:
Package contents:
Currently there is only a basic setup but as the developments advance so will the documentation. Start by mounting the big quad deck on the frame. After that connect the ESCs according to the diagrams below.
CFLAGS += -DENABLE_BQ_DECK
