BigQuad expansion deck
Specification
  • 4 x ESC connectors
    • CPPM input (3 pin)
    • GPS input (4 pin)
    • I2C expansion (4 pin)
    • Buzzer output (2 pin)
Electrical specification:
Mechanical specification:
  • Weight: 3.8g
  • Size (WxHxD): 36x40x5mm
Package contents:
  • 1 x BigQuad deck
  • 4 x M2x4 nylon screw
  • 2 x M2x6 hex spacer
Schematic
Setting up
Basic connection diagram
Basic connection picture
Attaching the Crazyflie 2.0
If the frame allows the Crazyflie 2.0 motors can be kept mounted but it is fine to remove them as well. Attach and connect the Crazyflie 2.0 using either the long or short deck pins. Use the included nylon spacer and screws to secure the Crazyflie 2.0 in place and to keep it level.
Building Firmware
Enable BigQuad features
CFLAGS += -DENABLE_BQ_DECK
Current firmware status notes (2016-03)
  • When the BQ-Deck is detected it will automatically switch to brushless motor drivers. It will be noted in the cfclient console if it detected it or not.
  • External battery voltage/current reading is implemented but no logic behind it, so don't run out of battery. You can connect the cable (MON port) and watch the log variable.
  • The PWM output is set to 400Hz. Use ESCs which can handle this or compile with new value.
Reference setup
projects/crazyflie2/expansionboards/bigquad.1459039858.txt.gz · Last modified: 2016-03-27 01:50 by fred
