BigQuad expansion deck
Specification
  • 4 x ESC connectors
    • CPPM input (3 pin)
    • GPS input (4 pin)
    • I2C expansion (4 pin)
    • Buzzer output (2 pin)
Electrical specification:
Mechanical specification:
  • Weight: 3.8g
  • Size (WxHxD): 36x40x5mm
Package contents:
  • 1 x BigQuad deck
  • 4 x M2x4 nylon screw
  • 2 x M2x6 hex spacer
Schematic
Setting up
Basic connection diagram
Basic connection picture
Attaching the Crazyflie 2.0
Building Firmware
Enable BigQuad features
CFLAGS += -DENABLE_BQ_DECK
Current firmware status notes (2016-03)
  • When the BQ-Deck is detected it will automatically switch to brushless motor drivers. It will be noted in the cfclient console if it is detected or not.
  • External battery voltage/current reading is implemented but no logic behind it, so don't run out of battery. You can connect the cable (MON port) and watch the log variable.
  • The PWM output is set to 400Hz. Use ESCs which can handle this or compile with new value.
Reference setup
projects/crazyflie2/expansionboards/bigquad.1476089003.txt.gz · Last modified: 2016-10-10 10:43 by tobias
